Hi, I reinstalled my gf's pc after using her HDD.
Using my disc with XP SP2 I got a blue screen after rebooting when install finished. Tried with my older XP disc which has SP1 only and the same problem happens. The last working install was with SP1 I believe.
As the problems now occur with both versions, would it be worth getting hold of an old XP disc from the early days with no SP's integrated?
The spec is:
Some old P4 running at 2ghz. 512mb of ram and a seagate 60gb 7200rpm HD.
Any ideas as to what is going on?
My gf is getting pretty frustrated :|
[edit]worked with bog standard XP, without any service packs[edit]
The spec is:
