Blue screens at startup
2 Jun 2007
Mornington Crescent
My PC had been sitting in the loft for a couple of months while I was at uni. Then mid november my parents brought it back down into my room as they were worried the cold may do something to it.
Since that happened, I've been getting bluescreens at startup. it Posts fine, and vista starts to load, with the loading bar, then it goes. It can take a couple of trys to get into Vista, but then it works fine. When I login, I get the 'Windows has recovered from an unexpected shutdown' box with details of the bluescreen.
Additional information about the problem:
BCCode: c5
BCP1: 00002AA8
BCP2: 00000002
BCP3: 00000000
BCP4: E24E8874
OS Version: 6_0_6000
Service Pack: 0_0
Product: 256_1
I looked at the minidump file in windbg and apparently its 'Probably caused by : ecache.sys ( ecache+4a7a )'
Is there much I can do?
