Blue Screens
10 Oct 2010
Hay all. Ok i have a problem.
From time to time i get Blue Screens pop up and it restarted the computer.
I dont always have enough time to read what the error message is as the comp reststarts.
The last time it did with i did see "memory management" but the error messages can be different
I have run memory tests and there is no errors.
Its recently new 2 2GB sticks of DDR2 Corsair XMS2 1066
Also Corsair ram cooler RAM Fans to keep them cool.
Also im on Windows 7 Proffesional 32 BIT
Any help would be great. Many thanks
The system is overclocked here are some screen shots
Probably an unstable overclock imo, try running at stock speeds/voltages for awhile, see if it still happens.
I havn't used it, but I've seen it mentioned a few times blue screen view that along side event viewer may help narrow it down.
You can also disable the restarting when it blue screens, right click '
my computer - properties - advanced - system and startup, it's in there.
Think on my laptop I can also press f8 when booting up and disable it from there.
ok I have down loaded BSV and i can see all the main errors. I dont really know what im looking at with these errors maybe you can have a look and see what you think.
Many Thanks
Dump File : 120810-25428-01.dmp
Crash Time : 08/12/2010 01:21:48
Bug Check String : MEMORY_MANAGEMENT
Bug Check Code : 0x0000001a
Parameter 1 : 0x00041287
Parameter 2 : 0x00510e10
Parameter 3 : 0x00000000
Parameter 4 : 0x00000000
Caused By Driver : Ntfs.sys
Caused By Address : Ntfs.sys+c9ed
File Description : NT File System Driver
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16385 (win7_rtm.090713-1255)
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120810-25428-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File : 120710-24632-01.dmp
Crash Time : 07/12/2010 18:19:38
Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000008e
Parameter 1 : 0xc0000005
Parameter 2 : 0x08b918da
Parameter 3 : 0xa5407cb4
Caused By Driver :
Caused By Address :
File Description :
Product Name :
Company :
File Version :
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120710-24632-01.dmp
Major Version : 15
Dump File : 120710-21652-01.dmp
Crash Time : 07/12/2010 11:45:54
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x00000050
Parameter 1 : 0xe9a42b40
Parameter 2 : 0x00000008
Parameter 3 : 0xe9a42b40
Parameter 4 : 0x00000002
Caused By Driver : halmacpi.dll
Caused By Address : halmacpi.dll+5ba9
File Description : Hardware Abstraction Layer DLL
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120710-21652-01.dmp
Major Version : 15
Dump File : 120610-22354-01.dmp
Crash Time : 06/12/2010 02:17:05
Parameter 1 : 0xc3d41a8e
Parameter 2 : 0x00000000
Parameter 3 : 0x8ba512c2
Caused By Driver : ntkrnlpa.exe
Caused By Address : ntkrnlpa.exe+85903
File Description : NT Kernel & System
File Version : 6.1.7600.16617 (win7_gdr.100618-1621)
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120610-22354-01.dmp
Major Version : 15
Dump File : 120610-22339-01.dmp
Crash Time : 06/12/2010 02:14:20
Parameter 1 : 0xc000001d
Parameter 2 : 0x8ba5fd00
Parameter 3 : 0xaad17be4
Caused By Driver : mfehidk.sys
Caused By Address : mfehidk.sys+2dd00
File Description : McAfee Link Driver
Product Name : SYSCORE
Company : McAfee, Inc.
File Version : SYSCORE.14.2.0.940.x86
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120610-22339-01.dmp
Major Version : 15
Dump File : 120610-24008-01.dmp
Crash Time : 06/12/2010 02:02:44
Parameter 2 : 0x83441b4b
Parameter 3 : 0x8cf9f958
Caused By Address : ntkrnlpa.exe+237b4b
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120610-24008-01.dmp
Major Version : 15
Dump File : 120610-23446-01.dmp
Crash Time : 06/12/2010 01:40:59
Bug Check String : PFN_LIST_CORRUPT
Bug Check Code : 0x0000004e
Parameter 1 : 0x00000099
Parameter 2 : 0x00048a38
Parameter 3 : 0x00000002
Parameter 4 : 0x00087a36
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120610-23446-01.dmp
Major Version : 15
Dump File : 120510-22526-01.dmp
Crash Time : 05/12/2010 20:29:04
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : 0xff000064
Parameter 2 : 0x00000002
Parameter 4 : 0x827df780
Caused By Driver : mfeavfk.sys
Caused By Address : mfeavfk.sys+9780
File Description : Anti-Virus File System Filter Driver
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120510-22526-01.dmp
Major Version : 15
Dump File : 120510-23571-01.dmp
Crash Time : 05/12/2010 20:14:49
Parameter 1 : 0xffeb0364
Parameter 3 : 0x8346b2c0
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120510-23571-01.dmp
Major Version : 15
Dump File : 120510-29702-01.dmp
Crash Time : 05/12/2010 19:16:58
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x0000000a
Parameter 1 : 0x51751a80
Parameter 4 : 0x8324d0cb
Caused By Address : ntkrnlpa.exe+4682b
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120510-29702-01.dmp
Major Version : 15
Dump File : 120410-22323-01.dmp
Crash Time : 04/12/2010 19:08:02
Bug Check String : UNEXPECTED_KERNEL_MODE_TRAP
Bug Check Code : 0x0000007f
Parameter 1 : 0x0000000d
Caused By Driver : CLASSPNP.SYS
Caused By Address : CLASSPNP.SYS+5565
File Description : SCSI Class System Dll
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120410-22323-01.dmp
Major Version : 15
Dump File : 120310-21340-01.dmp
Crash Time : 03/12/2010 23:17:35
Parameter 1 : 0x0000a0c0
Parameter 3 : 0x00000001
Parameter 4 : 0x83276f87
Caused By Address : halmacpi.dll+5924
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120310-21340-01.dmp
Major Version : 15
Dump File : 120310-22510-01.dmp
Crash Time : 03/12/2010 23:11:19
Parameter 1 : 0x8143dbfe
Parameter 3 : 0x8143dbfe
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120310-22510-01.dmp
Major Version : 15
Dump File : 120310-21808-01.dmp
Crash Time : 03/12/2010 22:44:47
Caused By Address : mfehidk.sys+36c72
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\120310-21808-01.dmp
Major Version : 15
Dump File : 113010-22136-01.dmp
Crash Time : 30/11/2010 16:50:49
Parameter 2 : 0x00617b38
Caused By Driver : fltmgr.sys
Caused By Address : fltmgr.sys+3414
File Description : Microsoft Filesystem Filter Manager
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\113010-22136-01.dmp
Major Version : 15
Dump File : 113010-20529-01.dmp
Crash Time : 30/11/2010 14:03:57
Parameter 1 : 0x00d68594
Parameter 4 : 0x83286158
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\113010-20529-01.dmp
Major Version : 15
Dump File : 112810-22167-01.dmp
Crash Time : 28/11/2010 00:34:56
Parameter 1 : 0xffffffe8
Parameter 2 : 0x00000001
Parameter 3 : 0x832a9efe
Caused By Driver : PCTCore.sys
Caused By Address : PCTCore.sys+2d88f
File Description : PC Tools KDS Core Driver
Product Name : Kernel Driver Suite
Company : PC Tools
File Version : 2.0.0.37 built by: WinDDK
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\112810-22167-01.dmp
Major Version : 15
Dump File : 112710-21434-01.dmp
Crash Time : 27/11/2010 18:24:29
Caused By Address : fltmgr.sys+14ae
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\112710-21434-01.dmp
Major Version : 15
Dump File : 112310-25833-01.dmp
Crash Time : 23/11/2010 23:03:17
Parameter 1 : 0xff5c9da0
Parameter 3 : 0x832a7bb4
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\112310-25833-01.dmp
Major Version : 15
Dump File : 112310-21559-01.dmp
Crash Time : 23/11/2010 19:18:33
Caused By Address : ntkrnlpa.exe+46f6b
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\112310-21559-01.dmp
Major Version : 15
Dump File : 112110-20545-01.dmp
Crash Time : 21/11/2010 20:31:28
Parameter 2 : 0x00117020
Caused By Address : fltmgr.sys+3841
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\112110-20545-01.dmp
Major Version : 15
Dump File : 111610-23056-01.dmp
Crash Time : 16/11/2010 19:21:36
Parameter 1 : 0xff93ce50
Parameter 4 : 0x830e71dc
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\111610-23056-01.dmp
Major Version : 15
Dump File : 111310-25069-01.dmp
Crash Time : 13/11/2010 22:54:53
Parameter 2 : 0x0009f8ef
Parameter 4 : 0x0009f8ee
Caused By Address : ntkrnlpa.exe+dcd10
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\111310-25069-01.dmp
Major Version : 15
Dump File : 110910-21528-01.dmp
Crash Time : 09/11/2010 13:32:30
Bug Check String : CACHE_MANAGER
Bug Check Code : 0x00000034
Parameter 1 : 0x00050830
Parameter 2 : 0x8db73958
Parameter 3 : 0x8db73530
Parameter 4 : 0x830baf55
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110910-21528-01.dmp
Major Version : 15
Dump File : 110910-23571-01.dmp
Crash Time : 09/11/2010 03:50:49
Parameter 1 : 0x80dfffec
Parameter 4 : 0x830df1f8
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110910-23571-01.dmp
Major Version : 15
Dump File : 110910-43742-01.dmp
Crash Time : 09/11/2010 00:03:00
Bug Check Code : 0x1000007f
Parameter 1 : 0x00000008
Parameter 2 : 0x801e1000
Caused By Driver : atikmdag.sys
Caused By Address : atikmdag.sys+2c2abb
File Description : ATI Radeon Kernel Mode Driver
Product Name : ATI Radeon Family
Company : ATI Technologies Inc.
File Version : 8.01.01.1094
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110910-43742-01.dmp
Major Version : 15
Dump File : 110810-20389-01.dmp
Crash Time : 08/11/2010 14:03:46
Parameter 1 : 0x0000c720
Parameter 4 : 0x830dcded
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110810-20389-01.dmp
Major Version : 15
Dump File : 110810-34195-01.dmp
Crash Time : 08/11/2010 02:51:29
Parameter 1 : 0x00000117
Parameter 3 : 0x00000008
Parameter 4 : 0x00000117
Caused By Address : halmacpi.dll+5b29
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110810-34195-01.dmp
Major Version : 15
Dump File : 110710-42557-01.dmp
Crash Time : 07/11/2010 20:33:31
Bug Check String : SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000007e
Parameter 2 : 0x831ed724
Parameter 3 : 0x8db87ad8
Parameter 4 : 0x8db876b0
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110710-42557-01.dmp
Major Version : 15
Dump File : 110710-39624-01.dmp
Crash Time : 07/11/2010 20:27:41
Parameter 2 : 0x83215724
Parameter 3 : 0x8db9bad8
Parameter 4 : 0x8db9b6b0
Caused By Address : halmacpi.dll+3800
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110710-39624-01.dmp
Major Version : 15
Dump File : 110710-29484-01.dmp
Crash Time : 07/11/2010 20:12:41
Parameter 2 : 0x5d098547
Parameter 3 : 0xa4bddae4
Caused By Driver : nsiproxy.sys
Caused By Address : nsiproxy.sys+2f1c
File Description : NSI Proxy
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110710-29484-01.dmp
Major Version : 15
Dump File : 110710-29343-01.dmp
Crash Time : 07/11/2010 18:05:26
Parameter 2 : 0x8b854d00
Parameter 3 : 0xa2777be4
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110710-29343-01.dmp
Major Version : 15
Dump File : 110710-30638-01.dmp
Crash Time : 07/11/2010 17:58:50
Caused By Address : Ntfs.sys+8db48
Processor : 32-bit
Computer Name :
Full Path : C:\Windows\Minidump\110710-30638-01.dmp
Major Version : 15
Have you tried running without your overclock? You need to reset your CMOS and run your PC at stock for a few hours or even a few days.
If your errors go away, you have an unstable OC.
If they remain, you can start looking into the errors. Interestingly I see a McAfee driver throwing a wobbler in that lot. I also see lots of filesystem driver errors. Which could point to a dodgy HDD/damaged filesystem.
Hard to say really. You need to get rid of the OC though. Utterly pointless trying to diagnose this until the OC has been ruled out.
ok good idea mate..
