Blue streak
8 Apr 2004
OXFORDSHIRE
I could be in the wrong sub forum here but i dont know which is the right one.
I have this light blue streak running down the middle of Ebays web page - its only ever Ebay, no other web pages display this. It seems to be a corruption of the other proper blue lines on the page, like the one going across the bottom, which is meant to be there.
I can get rid of this vertical blue streak by logging out and back in, but a simple page refresh will not solve it. It has to be a log out / log in action.
Is it Windows prob ? Java prob ? Ebay prob ? I discounted a graphic prob with either card or monitor, because its only happening on Evilbay.
Opera 9.63 + win XP pro - what link is it you need ?
I should say that this has only been happening for the last couple of days, and would also like to ask if it could maybe be a RAM problem as i only have about 756mb
I ought to check, but i never use it, but i'll shut everything down and open Fleabay in IE to have a look. I can also check it with Firefox
Ok - i opened Firefox and like Opera, the blue streak is not on the main Fleabay page, but appears when i'm in my Fleabay account.
Exactly the same happens with IE
Edit. I have a hunch this is an Ebay prob, as this streak is only appearing on my account page. I've just looked at some auctions, and the streak isnt there. When i click " back to my ebay " ( not using the back button ) it re-appears
