Bluefin Superchips alternative?
Caporegime
24 Oct 2012
Yer nan's knickers
Before I pull the trigger on a £250 Bluefin Superchip for my R50 Mini, is there a cheaper way to do this?
I'm looking at options on eBay but that's a minefield I'm not very keen on. They go from the usual resistor trick to more sophisticated, more expensive units like this one.
I have no idea how an ECU works so any advice on this is greatly appreciated.
If not I'll just buy the Bluefin.
Bluefin is probably the best off the shelf map for a standard ish car. Plus you can reflash the stock map and back again at will.
If your modded then most enthusiast forums can give advice on slightly more customised ones, for example RICA tuning for Volvo and saab... Beyond that you want a full custom ecu/map tailored to the vehicle.
I'd go with a bluefin as a cheap easy option, I really wouldn't trust any brown box stuff from eBay.
And forget claims of peak power output, what you want is something that gives power at usable revs, that makes the car respond and feel much more sprightly.
My bluefin (BMW 335d) was about 40 BHP down on what it claimed, but I didn't really care. It was acceptable, and cheap enough, and I could take it off when I sold the car, and sell on the unit itself.
The only similar map to that I had before was a ChippedUK ST3 (now viezu or something). It was also excellent though, and allowed me to switch between 3 different maps. Ran that for around 3 years on a A3 2.0 TDI.
To be fair though, it's a switchable, generic remap. Get one from a respected tuner, and they will all be much the same.
Agreed. Superchips are a well respected company. I Bluefin'd mine and gained 40bhp. Slightly down on their claims as seems to be most peoples' experience, but hey ho that's marketing. There's noticeably more power and it's money well spent IMHO!
Yeh it's not peak power you notice so much, it's the better smother torque and power through the Rev range where you really notice it.
