Bluescreen error?
17 Jul 2010
Im not sure if it's a graphics problem but ive had a bluescreen error come up a couple of time and I tried running Sandra and it stopped with "Error 8111" on graphics tests.
the bluescreen error reads
Local id 2057
BC CODE 7F
BCP1 0000000000000008
BCP2 0000000080050033
BCP3 00000000000406F8
BCP4 FFFFF800030E3679
VERSION 6-1-7601
SERVICE PACK 1-0
PRODUCT 768
MY RIG:
I5 4670K @4.2
Z87 G43 MSI MOBO
16 GB 1866 C9 TRIDENT
GTX 770 OC EDITION
xfx 850w psu
Any help would be great not seeing a lot online Ive took the card and wires out and replaced it and run Sandra again and it stops with the same code?
Had it overclocked at 4.2 then scaled it back to 4.0 @1.12v ran prime 95 overnight and it seemed fine.
Guess I could take off the overclock and try some games?
Prime 95 proves it can run Prime 95 nothing more. Play your games or use as you normally would to test stability for your uses. 7F actually usually mem / IMC / Uncore type stuff not always Vcore.
Ive put all the settings on auto in the bios so its not overclocked at the moment and have tried a couple of tests and some gaming.
One of the tests was Sandra's burn in and I keep getting error 8111 and stopping on the gpu test again?
Only if you want to remove them. GeForce Experience is part of the driver package, unless you're removing the card or manually updating the drivers, there's no need to remove it!
Still getting 8111 error on Sandra for benchmark general purpose?
Still in the process of testing things out gaming etc not easy working atm
Right ran sfc chkdsk scans and nada.
So I used bluescreenview one of the issues was Kaspersky driver apparently the link amazon gave me when I bought it was to an older version causing klim6. errors.
Hopefully sorted that out by upgrading to the newest version but two other crashes were caused by ntoskrnl.exe are they both linked?
BTW thanks for all the help so far folks!
And I tried running Sandra burn in on the same settings and no issues!!
Hopefully that's it cant believe it was bloody Kaspersky that caused all the issues Malwarebytes updated itself three days ago too.
Fingers crossed and thanks for all the help everyone :-)
