Bluescreen Help Please!
31 Mar 2006
Gravesend, Kent
Hey all,
My sisters laptop keeps bluescreening and am not sure why :(
It has 'slow moments' where everything grinds to a halt and then slowy picks itself up again. I have tried reinstalling XP twice and that never helped. All help would be appreciated! More detailed bluescreen below
Matt
Code:
KERNAL_DATA_INPAGE_ERROR
Technical Information:
*** STOP 0x0000007A (0xc03E4734, 0xc000000E, 0xF91CD642, 0x0A750860)
***     ftdisk.sys - Address F91CD642 base at F91C3000, DateStamp 3b7d8419
Here is a quick link for you - http://www.osronline.com/ddkx/ddtools/bccodes_2vjb.htm
Do the following
1) Confirm that paging file is not too small for the amount of installed memory
2) run chkdsk /f /r to repair bad blocks in paging file (requires reboot)
3) check/replace SCSI cables and termination
4) check seating of memory and other boards
5) update firmware, service pack, and drivers
Ive known people to have this before, its normally the hard drive on its way out or a problem with RAm but can be little things aswell. hope this helps
when my laptop did it. the heatpipes and fan was all clogged up just unscrew the back pull all the fluff out and away you go.
ok, to access the fan you need to take the whole case apart (stupid design :() so i have swapped the hard drive with a spare i have found. I also did a memory test and it turned out ok. thanks for your help, lets hope this works!
