Bluescreen help
11 Dec 2007
Rochestet, Kent
Hi all,
Not sure why this happened by I just had an 0x3b BSOD whilst running a game in a window with Google Chrome in the background. After restarting I received a POST fail stating a graphics card issue. Restarting again boots Windows normally.
I've had a few problems that I think points to the motherboard recently like the POST error I stated and USB devices not working after getting the POST error.
Now I have gotten as far as debugging the minidump, but I haven't got a clue as to what I'm looking at!
Hope someone can help.
Full Log: http://pastebin.com/rfAdHrin
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff800030a21aa, Address of the instruction which caused the bugcheck
Arg3: fffff8800bbe91a0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
FAULTING_IP:
nt!KeDelayExecutionThread+18e
fffff800`030a21aa 0000 add byte ptr [rax],al
CONTEXT: fffff8800bbe91a0 -- (.cxr 0xfffff8800bbe91a0)
rax=0000000000000102 rbx=0000004064a4f289 rcx=0000000000000000
rdx=00000000000007ff rsi=0000000000000000 rdi=fffffa8006d6f060
rip=fffff800030a21aa rsp=fffff8800bbe9b80 rbp=fffffa8006d6f16c
r8=fffffa8005d4ebb8 r9=0000000000000000 r10=fffffffffffffffe
r11=0000000000000000 r12=fffff8800bbe9c30 r13=0000000000000001
r14=0000000000000000 r15=fffff78000000008
iopl=0 nv up ei pl nz na pe nc
cs=0010 ss=0000 ds=002b es=002b fs=0053 gs=002b efl=00210202
nt!KeDelayExecutionThread+0x18e:
fffff800`030a21aa 0000 add byte ptr [rax],al ds:002b:00000000`00000102=??
.cxr
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x3B
PROCESS_NAME: svchost.exe
CURRENT_IRQL: 0
