Bluetooth adaptor for Xbox One (S) pad on PC?
19 May 2005
Doncaster
Hi,
Can anyone recommend a USB bluetooth adapter that works with the latest Xbox One S controller wirelessly on PC? (Windows 10 btw) If it also works with a Dual Shock 4 that would be a bonus. I bought the Asus BT400 one OcUK sell in the past (to use with a DS4) only to find it apparently doesn't work with controllers period.
Cheers.
I use a Kinivio BT400 with DS4 on Windows 10, can't remember the name of the software I use atm but it works wireless or wired, just turn the pad on and Windows picks it up. Don't know if it works with the new Xbox controller though.
Got my xbone pad and it turns out it does work with my Asus BT400. Just putting this info here in case anyone searches for the same thing.
the pad as to be Bluetooth to works with a B adapter. only the new type pads are BT google will show you what to look for.
my 2 pads both work with a cheap TPlink 4.0 BT adapter
