Bluetooth audio delay/sync app?
NVP
NVP
6 Sep 2007
[android]
Does anyone know if such a thing exists so I can delay the Bluetooth audio when using iplayer for example?
Thanks
If you go into developer options on your phone / tablet you can usually change the codec being used for Bluetooth. Changing these has sorted most sync delays for me in the past
Haha yeh, cheers ;)
Nah its usual Bluetooth audio delay, decent apps allow for sync like VLC etc but things like iplayer don't so I was wondering if there was a general app which would let you adjust all phone media audio at will.
Thanks, maybe this will help. Any recommended codec?
Have a read of this, near the bottom. I'll have a look on XDA as well.
PS - don't forget to get your software information for your old N4 so I can point you in the right direction for updating to that ROM.
