Bluetooth Audio Problem (Profile switching?)
28 Apr 2011
Barnet, London
I'm trying to use a Bluetooth headset with my laptop running Windows 11. I'm using it on some language learning software where it will play audio and then I need to repeat it.
As it plays, after a second I can hear it crackle, cut out for a split second, then come back in clearer audio. Then it switches to listen to me repeat it. It pings, I have to wait for a second for the mic to activate before I then talk.
From a little googling I think when it's playing audio it's switching from HSP (Headset Profile) to A2DP. Then when I need to talk, it switches back to HSP. Both times there's a little delay and interruption while switching. Can I force it to just stay in HSP?
Do you have the option to select the default playback device?
Settings, System, Sound, More sound settings. On the playback tab there might be more then one device.
I had a Sennheiser M3 headphone which would do something similar, background music would sound terrible in headset mode, I think I was switching between MS Teams calls and Spotify. Gave the headphone to my son and went back to wired.
Thanks, when on and connected, it seems to be the default device. What I did notice on the 'more sound settings' window, is when I made noise there were two sound level bars moving. One was for my webcam. I disabled that and it seems to have fixed the problem!
