Bluetooth Earphones with iphone 8
24 May 2022
Dublin
Hi,
Sorry if it is a dumb question but,
I was thinking of getting these Bluetooth Earbuds . It doesn't seem to say if it is compatible with iphone or not. Can I just assume they will work with my iPhone 8 if they are bluetooth?
ie. Will they just appear if I do a bluetooth scan?
If you check the last picture it does show it works with iOS. I can't see what codecs it supports so it'll most likely fall back to SBC, so don't expect the best quality if you plan on using it for music. Ideally you want something that supports AAC.
