Bluetooth Keyboard and Mouse
4 Oct 2022
Manchester
Any recommendations for bluetooth KBAM? I don't need anything fancy as I play controller with my PC games. Though I will need it to connect to two different devices; my home desktop and work laptop. Is this even possible?
I use my work laptop to display 2 monitors through a Dell dock, and when this is turned off I will switch on my desktop. They're both never switched on at the same time.
Thanks,
Jonny
K380 Logitech keyboard is great. I used it on my Mac.
Not sure about mouse though? Mabye a MX Master??
The keyboard looks great. Small form works perfectly for my desk setup. There is a mouse bundle by Logitec as well. It's actually cheaper buying them separately than as a bundle, only £5 but it helps!
I picked up the keyboard and mouse combo, bought separately, of course! The multi device bluetooth setup on the keyboard is so easy to use. I bought the M705 Marathon mouse as well, which uses the unify dongle. Quick switchup from work laptop to home desktop USB ports makes it a very easy switch too.
Really happy, thank you for the recommendation! Purchased both together for £65 - keyboard for £25 and mouse for £40.
Nice one mate. Your welcome!
Thought I had a problem with the keyboard as it was lagging a lot and putting in loads of random letters. Turns out it was a Fitbit charger in my desk drawer under the keyboard. The magnet on the charger was interfering with the keyboard!
