Bluetooth Keyboard & Mouse Switch
25 Feb 2007
Midlands
Hi,
Does anyone know if the above exists?
At the moment I have two machines on my desk, that I want to control using the same Bluetooth keyboard and mouse (not at the same time).
Currently I have to disable Bluetooth on one machine and enable it on the other, in order to switch the pairing of the peripherals. This works, but is annoying!
I’ve seen the Logitech Craft keyboard/mouse which enables pairing between 3 devices and can be switched using buttons on the keyboard.
I wondered if there was some way to apply this to my existing setup.
Thanks,
The solution over bluetooth is to use a device that supports multiple host devices(like the Logitech one), many bluetooth devices are designed for use with a single host device. If you're running both systems at once, KVM or remote desktop seem like the most immediate solutions.
I have the MX Master 2s and that works with multiple machines via a button at the bottom. Also has a cool feature in logitech options where you can just mouse outside of your screen and it will jump to the other computer like having an extended desktop.
