Bluetooth mouse for my macbook pro
17 Oct 2006
Aviemore, Cairngorms, Scottish Highlands
I got a sexy macbook pro in silver and want a nice mouse to go with it, if i go for a bluetooth one will it work with my bootcamp xp install :D
If so what is there on offer.
I have the Wireless Mighty Mouse and i love it.
Best mouse to use in OS X imo.
It is a bit marmite though. Mine is very good, my mate bought one and it was terrible though, felt really cheap. I have had 2 and there both awesome.
Josh
Mighty mouse is good as long as you don't need to right click too often. It has one and it sometimes works, but I think I'm going to get a new mouse with separate buttons as it gets annoying sometimes.
The trick with the right click is that you have to take your left finger off the mouse. It senses that your left finger is off the mouse then right clicking is easy.
Josh
I only think the Wireless one is good (the laser one, the optical one is bad). My mates wired one he go with his iMac was terrible, felt very cheap and didn't work very well, must have been because it was optical.
Josh
