Bluetooth Mouse?
30 Dec 2005
Hi guys
I have had a Logitech v470 mouse, infact had 2, they have been decent but the scroll wheel seems to get messed up and hard time scrolling.
Is there anything else to replace it with, something similar size too
thanks
Might be worth trying the technique used on the old Magic Mouse, lay a damp cloth out flat on a table, and roll the wheel back and forth over it for a spell, if the issue is something to do with bits of dust/dirt/hands etc... getting stuck in there it might help you out. If not, I would get in touch with Logitech as they will likely replace it for you FOC. Their warranty/customer support is amazing.
Thanks mate, this is actually my third one. Cleaned out the scrolled button but still seems abit crap. Might buy another one if I can find it for a decent price.
