Bluetooth music on ear phones too quiet?
4 Feb 2004
Écosse
I have a Huawei P30 Pro and I use it with motorcycle BT comms between my pillion and also bike to bike when mates are in range (400m max).
The BT bike comms are Interphone Cellularline Connect units. But what I'm finding is that when trying to listen to music the volume is very, very low even at max setting on the phone. The comms units are also set to maximum volume using the buttons on the units body.
I'm using 'Ear-peace' earplugs to guard against wind noise and have the minimum db filter in, but even without them just to see if there was a difference, the volume is still really low.
Any advice on what to look at would be appreciated.
Go to developer settings and disable bluetooth absolute volume, reconnect the bike comms and see if that's any better?
