 - 21 May 2003
My upload speed maxed out at around 44-46 kpos and was pretty stable. Now it's dropped to 29 kbps. I'm not happy about this at all.
			Where are you downloading from? Have you tried the BY FTP?DanMc07 said:my download rate is absolutley crap. im on 10mb and downloading at 120-240. anyone else in my area gettin it? BS to be honest
think they mean this http://gamefiles.blueyonder.co.uk/SherberT* said:BY FTP? LINKZ0r please.
ftp://gamefiles.blueyonder.co.uk/?volt9291 said:think they mean this http://gamefiles.blueyonder.co.uk/
Phunky said:Just tell them you dont have a router then? Or connect straight to the cable modem while your on the phone with them.
tbh most issuse can be solved by changing the contention ratio line that your using, aslong as you have a Surfboard or a Webstar with updated firmware you can easy change it!
Broadband Speed Test Results
Results from broadband speed test recorded on Thursday, 11 May 2006, 12:27.
Your Connection
Speed Test Results
Downstream 2,035.8 Kbps ( = 2.0 Mbps )
Upstream 83.5 Kbps ( = 0.1 Mbps )
