Bluray corruption above 9.6 Catalyst
3 May 2004
Scotland
Hi
I have a media center with a built in HD3200, The board was built and certified to play bluray and it does perfectly until i go above catalyst 9.6, Im using powerDVD 9 to play back, as soon as i go any higher than th 9.6 cats i get lines and flicker during playback.
Im playing 1080p on a 42" Samsung, these drivers are the issue and i know im not missing much by having older drivers on a MCE
Also if i reduce the size of the screen and then have a bowser open i see the same corruption when scrolling down web pages, When i close powerDVD all returns to normal
Anyone seen or solved this issue? Im finding it difficlut to google because all i get are the driver fix logs saying this has been fixed back in 9.1 or something.
