I doubt it as you have to be a licensee and that costs money. Don't most drives/computers with BluRay come with an OEM version of the Cyberlink app that plats them though?
ok i did have a disk! installed cyberlink dvd, everything seemed fine, put a blu ray in. It said it needed an update for it. Fair enough. Downloaded it, attempted to install it and it didn't even work! Some error saying it can't find an intel 32 folder preventing it from installing. What a waste of time! ffs!
It definitely should work, did you install the whole cyberlink suite or just pdvd? I've done this at least twice (updating it that is) on vista x64 and it was fine. What OS?
yeah it was the whole cyberlink suite thing. its windows 7 x64 but i shouldn't have thought it would make that much of a difference considering windows 7 has vista engine really? hmm.? dunno more annoying than anything
It's not really a case of having the same 'engine'. It's a modified vista kernel but optimised and designed to be more modular I think. There are similarities for sure, but they're definitely not the same.
Have you tried downloading the update and running it in compatibility mode for vista sp2?
