Blurred Games
21 Aug 2003
Kind of an odd problem I'm having;
Lately I've gone to play a game and it has been blurred slightly. In Guild Wars the entire game is blurred (menu, text, graphics) and in UT2004 the font is blurred. It's as if the game was not set to the right resolution and was being stretched (I have a TFT). I have re-installed graphics drivers and made sure the resolution in game is set to 1280x1024. Any ideas?
Thanks.
Maybe you could post a screenshot of the problem?
I dont think I can help but it might make it easier for the people who can! :)
Here is a screenshot:
Forget about the .JPG compression, it looks like that anyway and I used Photoshop to convert it.
I have a 17" TFT with a resolution of 1280x1024.
TBH try turning AA/AF off and on. Text has a nasty habit of going scatty with 3D effects (Especialy CS :\) COuld it be something to do with the annoying "Glow" post-render effects that are put on games nowadays? Try turning it off in GW to see if it helps/ If it doesn't help, turn it off anyway cuz it's horrid :p
Could it be the fact that the game is set to 60Hz refresh rate in the settings and your monitor is set at 70Hz or something higher?
Small update, it's happening in every game. My monitor is set to 60Hz (DVI) and I tried turning the post-processing off in Guild Wars; it stopped the game being blurred but text was still unreadable and I remember being able to use post-processing before with no disadvantages.
it my experience it could be 2 things, either its AA effecting it or you have Clear type turned on in windows :)
You're right guys, it is cleartype. Is there anyway I can still have cleartype on and keep my games unblurred? I have been using cleartype for years and this problem has only come on in the last few days...
