Blurred screen
25 Jul 2004
Hi Everyone
I have a Dell E173FP. It works perfect on one machine, but when i connect it to another, there is a slight blurring/shadowing of desktop icons and text.
Does anyone have any suggestions of what i could try?
Thanks, Phil.
That wouldn't cause shadows on desktop icons though. Shadows on desktop icons is usually caused by poor quality VGA cables, usually when ones that are only suited to res's up to 1024*768 are run at higher res's. Are you using the same VGA cable on both PCs? Also are you using the same resolution and refresh rate?
If its fine on one machine but blurred on another, the first thing I would check is the cables and graphic card.
