blurry applications RDC and live messenger with gtx 680
7 Jan 2011
Reading , UK
blurry applications RDC and live messenger with gtx 680- NOW SORTED CHEERS
im loving my GTX 680 - games are running beautifully
one issue i wondered whether anyone else had noticed - when trying to use RDC or windows live messenger the application is very blurry and is only cleared through movement of mouse
im using the release drivers atm - hopefully im not alone a quick search on net seems to show a few people with similar issues in remote desktop
ill try a re-install later on but as i say games BF3 skyrim and other apps are running perfectly
Make sure you update to 301.10 if your using 300.99 or earlier drivers. Does sound like your globally forcing FXAA on tho which is a bad idea - only enable it for games where you specifically need it as it works best with games that are programmed with it in mind and render certain things like text after the FXAA pass.
SORTED
thanks guys - that has done the trick :D
ill manage Crisis 2 and others individually
anyone got a list of games which support FXAA currently ?
