Blurry warhead..
7 Dec 2008
Scottish Borders
Anyone got a fix for the blurry texture in warhead? i remember i had the same problem with vrysis and after downloading one of teh ultra config's the problem was solved so i guess there must be some config tweak.
Can you chuck up a screenshot to show what you mean? Neither wahead nor the original look particularly blurry to me..
its probably something to do with SSAO, i have had blurred cliffs and stuff in warhead, when i have messed up SSAO settings, but they only usually happen with custom configs, rather than because of them :) as above chuck up a screenshot :)
It sounds like texture streaming is turned on, hence the blurry low resolution textures.
Put r_texturesstreaming=0 in your system config file in the game's folder inside program files. Should fix it.
