blutooth keyboard and mouse
30 Aug 2003
will this type of keyboard and mouse work like a blutooth headset, as in within a 10 metre range?
reason i ask is my PC is in the dining room and i use a transmitter to send the signal from the pc to the tv so that i can watch films from the pc on the tv, but going into the dining room to do anything is a bit of a pain and im lazy
will this work?
cheers
ive got the Logitech MX 5000 Laser Cordless Bluetooth and its **** its works about 3 meters away max and some time losses it signal if i was you i would stick with regular wireless not bluetooth
ok cheers
i dont think wireless will accomodate my needs either as their range i belive is even worse, and concidering i will want to use it in another room it might be too much to ask
I currently use the microsoft bluetooth keyboard/mouse and can use these through a couple of solid brick walls, so no problems for here.
Yeah mate I allso have the same problem mostly that I press a key and it wont respond then it will jump forward.
Shame cus its a great idea.
My Cordless MX Desktop works from downstairs to my room (about 5 meters) I think on the RF desktops you get better range depending on which one.
will this work?
cheers
Where can you get these transmitters please mate?
I've got an EPoX bluetooth keyboard (which didn't come with a dongle so I had to buy a belkin one!). Whilst I dont really recommend this keyboard (keeps turning itself off to save power and means I miss letters when typing) it does transmit through walls up to at least 5 meters away.
mx5000 works downstairs here, pc is upstairs.
IT depends on what version u get the new version has a seperate bluetooth 2.0 dongle, which is not built into the charge base.
Maybe the other user who posted has the older version which is bluetooth 1.0 which has a range of approx 3meters tops. 2.0 is supposed to be good for 10 meters with a clear signal.
