Hi guys,
My 320D partly died last week (reverse gear no longer works, not really worth sorting out) but annoyingly I'd brimmed the tank the previous day. While it's not the end of the world, it is a bit annoying that I'll end up ditching the car with a near-full tank of diesel. Is there an easy way to drain this out?
The only ways I'm aware of are:
1). Lift the back seats out and lift the carpet to get access to the two fuel pump/sender units. Take them out and then I will have access to the diesel there. Knowing my luck I'll trash something though.
2). Jack the car up, disconnect the fuel filter and sit there pushing the power button (but not starting the engine) for ages until the fuel is emptied out into a container. I've done this on another car but not sure if it'd work on this car.
Are there any other solutions anyone can think of? Or is it just not worth bothering with for £70 of fuel?
