BMW pre facelift E46 LED lights
Do not fit aftermarket lights, they never look good, they always look tacky. Do the conversion using OEM parts or dont do it :)
you need to re prog the LCM , a new wiring loom extension and ( depending on if the lights come with them ) a new light backpanel which contains the boot light
and as said pre 2001 ( if you do not have auto lights on ) then you need a new LCM
last thing is that the progressive braking thingy ( outer ring brighter under heavy braking ) will not work , you can wire it to always come on under all braking though
Is that the build date or the registration date? You'll probably just have to check when you get the car to see if it's ok as BMWs can be a bit blurry as to when things are changed. I've seen a 53 plate 330i with a 17 pin round pin radio connector and these were supposed to have changed in 2001. My Jan 2002 built 325ci also has the 17 pin connector.
