Board Going Weird
26 Sep 2007
Amsterdam
Can't seem to be able to get my 3ghz overclock stable anymore, I was using 1.41vcore (my BIOS knocks .03v of what I set off which isn't vdrop) so technically I'm using 1.38vcore with 1.5NB with 8x375 but it doesn't even post, it gets up to the Intel Processor bit with EM64T suppported but just freezes there. This used to be a 14 hour Orthos Stable overclock but now it doesn't even POST! I reboot a ton of times but the screen just stays black on the monitor. I eventually clear the BIOS and I can finally get in. I've gone all the way up to 1.45vcore (1.42 set) 1.5NB and it does the exact same thing. After rebooting about 15 times and every time getting greeted with a black screen talking about bootlock and keyboard not detected so I removed my USB eclipse and put in a PS/2 and it booted. It hasn't done it since then. This is really odd that it doesn't post, I already knew I had a FSB hole between 300-365 where the first boot with that setting the screen would stay black but the second boot it woould actually boot into windows. What the hell is going on?
Can I also add a problem that I've experienced since I built the PC, the CPU doesn't always show up on POST where it shows RAM clocks, IDE drives etc and sometimes it takes a long time to detect IDE/SATA drives.
