Bodging together a guest network?
Caporegime
25 Jul 2003
FR+UK
I've got an asus rt56nu (and two dlink 615s running dd-wrt as wireless APs/boosters) which doesn't have a guest network feature (unless its unlockable with custom firmware??). I'd like to have a guest network for visitors, can I bodge something together with the 3 routers?
I have a second linksys router that I'm using as an AP with guest network.
I actually have a ethernet over powerline adaptor that plugs into the main router, then another one in my room with a cable from the adaptor to the router.
I previously had it setup as a client bridge I think it was, but the signal wasn't strong enough at the end of the house, so this is why I am using adaptors.
That and the holiday let next door can pick up on it also.
So just be a case of going to 'wireless - basic settings - virtual interfaces' in the ddwrt?
If you want a guest network and 'your' network across all the APs then you're going to need to have the guest network on your router and then run that network plus the non-guest network as VLANs out to the other two APs. This assumes that those devices even support that, either with custom firmware or stock, and if you have 'dumb' switches in the mix then that's not going to work.
The other option I suppose would be to see if each AP can run a guest network as a self-contained thing, so each box runs DHCP and NAT to provide guest access. This will be reasonably bodge-tastic but should work if you don't move around while using the Wi-Fi.
I never got vlans/guest wifi to work with the 615, spent enough time banging my head on the wall over that one before finding out its not supported!
