I had a 'Nest Pro' install the Nest V3 we brought with us from my previous property.
I hooked it up previously as it was a simple wire up to the combi boiler, but the new house is on a unvented system. From what I can gather, the installer removed the old programmer (and I assume bridged some connections together), then installed the Nest Link near to the hot water tank so it controls the 2 X motorised two way valves (one for HW, the other for CH).
Literally since the install happend, the boiler will occasionally not fire up when needed. The Nest installer said the Nest is doing what it should, which I agree as when hot water or central heating is requested by the Nest, the valves are opening, the pump is running and there's a orange light on the boiler that shows it knows it should be providing hot water.
It's an oil fired boiler, and if I press the reset pin in, it fires straight up. We had a guy come around to check over the whole system, he said the reset pin I'm pressing usually only needs doing if the boiler has shut down due to overheating. He reduced the thermostat on the boiler itself, but it has still been hit and miss firing up.
Is there anything I'm missing? It seems too much of a coincidence this has stated since the Nest was installed but at the same time, the things the Nest controls seem to be acting as you would expect?
