- 8 Jan 2003
- Scotland
I'm looking for a flexible hose with a 22mm screw connection at one end and 15mm at the other. I can't seem to find one anywhere, do these actually exist?
Basically one of these: http://www.screwfix.com/p/wras-hose-22mm-x-15mm-x-500mm-x-10mm/40166
with the same fittings on the end as this: http://www.screwfix.com/p/wras-hose-1-2in-x-1-2in-x-500mm-x-10mm/82014
If it helps any, it's a filling loop for a boiler. For some reason known only to the person that fitted it, there was a washing machine type hose connected to a stop valve on the cold water mains (22mm) which went to another valve (15mm) on the pipework going into the boiler.
The plastic insert in the screw fitting on the 15mm broke last night so I was looking for a replacement. Seems most filler loops are 15mm to 15mm.
Failing that, do you get a 22mm male to 15mm female reducer?
