Hi
we moved around 6 months ago a a different property. It has a Baxi boiler from the dark ages thats noisy and looks ancient and a grasslin towerchron qe2 panel. We also have a hot water tank that seems to be gas only and no connection to the electric.
The problem besides the cold in the upstairs (can be 5-8 degree difference with it being cold upstairs) is when setting the heating to come on the hot water come on no matter what.
In my previous properties we could use the timer to do them separately and it worked. This panel has the options but no matter what we set the heating to the hot water comes on for the same time even if not programmed. If we set the hot water only...no heating comes on?
Is this normal? The tank is set to 65 degree's but with upstairs being a fridge, its always kicking in even when the rooms have reached temp. Can anyone also please explain how the numbers on the actual boilder affect the heating? I can turn it down to 2 etc the heating kicks off but obviously if the actual thermostat is not at temperature how can this affect this?
We have just recently had the landlord put in an extra 170mm insulation ontop of 80mm previous but it does not seem to have made a difference to upstairs. Downstairs is lush!
thanks
thanks
