Boiler man verdict. don't know if I should trust what he says
14 Jan 2010
Essex
We have an icos ideal condensating boiler that has been flashing code F L which basically means the boiler has failed to light after 3 attempts.
The boiler man came whilst I was at work and my wife was home and gives her the verdict that the boiler has a crack in the system but it is safe to keep on using for now.
Now the boiler is around 12 yes old so a replacement could be expected but unfortunately I don't necessarily trust this particular person that much and I wonder if what he is saying is true.
How can a boiler be deemed safe to use if it has a crack in the system?
Not all that clued up on boilers so happy to hear thoughts either way
Oh and BTW before you ask its a rented house and landlady chooses who fixes things
If you don't trust the guy, arrange your own boiler service/safety check.
Why do you care if you trust said boiler man?
Its a rented property, the boiler man says get a replacement as repair is uneconomical so landlord should be obliged to replace to keep the property in a habitable condition.
Rightly so, but I don't trust this guy and my landlady is good to us and treats us well. It is my obligation to look out her and stop her getting ripped off if I know for sure this guy isn't what he's cracked dup to be.
I for sure would want someone to tell me if they thought that was the case so I could at least get a second opinion, only problem is I don't have any proof of anything and no real knowledge about boilers to argue otherwise.
