In the attached photo, you can see a view of my boiler and plumbing system.
I've been dealing with an issue of increasing pressure in my boiler for the past few weeks. Normally, when all the valves are in the down position, the pressure increases to around 0.5-0.75 bar every night. I manually reduce the pressure by releasing water from the discharge valve.
Unfortunately, most technicians in Turkey are untrustworthy and charge exorbitant fees. So, I want to gather as much reliable information about my boiler issue before needing their services. That's why I'm turning to this forum for advice.
I've conducted several tests, and when I closed the valve on the right in the photo, I noticed that the pressure didn't increase. In my online research, I read that pressure increase issues could be due to a faulty heat exchanger, valve leakage, or expansion tank problems.
How can I determine the root cause of the problem? If the pressure doesn't increase with this valve closed, could replacing it solve my issue?
I appreciate your assistance and thank you in advance.
