Greetings,
I was hoping to sanity check the behavior of my boiler with you fine folks.
I have a Worcester green star 40cdi conventional boiler. The boiler is in Eco mode and set to a temperature of 50deg c.
The central heating is switched to off and the hot water is set to come on for 1 hour each day.
So in this condition the boiler seems to be firing every two or three minutes for around 10 seconds ( which is somewhat tedious to listed to at night).
Should the boiler be firing to keep itself at 50 deg c and ready for action? Or should the boiler remain silent and inactive I until there is an actual demand on it (e.g. a request to heat water)?
I can't help but feel that its current behavior is not quiet right...
Thanks
Thanks
