To start with, I have a Vokera 'Unica HE' boiler and it's not igniting.
I'm no expert, there was normally a clunking/banging noise (usually 2-3 times) when it would first turn on. That doesn't happen anymore and the boiler itself locks itself out after failing to ignite the gas.
The same symptoms appear when I switch it to hot water only and then turn a hot water tap on, attempts to start, fails, locks out.
I have checked and there is a spark, but that's not igniting the gas for whatever reason. Which leads me to think is any gas getting in there. Already tested house gas supply, left hobs on for a good 10 minutes and supply is fine.
My description probably isn't great, but since the only difference is that there's no longer a 'clunking/banging' noise when it first starts up, would this just be the pump isn't pushing the water around since it didn't ignite and completely unrelated? (I'm assuming the noise was a pump). I'm going to make some calls tomorrow to see if I can get someone to come look, but any ideas? Or any quick tests for this particular model?
