Boinc Help - Compute Errors
Permabanned
31 Jul 2005
I set up Boinc running Rosetta on my PC a few days ago and have just noticed i'm getting loads of compute errors on my results page.
I'm running everything at stock speeds. Orthos and Memtest don't find any errors.
Does this mean my pc isn't stable or is it a problem with boinc?
You should be stable, if you click on the task id or wu id, then you will get the output of the log which might give you a clue as to why. Then the rosetta forums should be able to provide a reason or help you solve it...
