BOINC problem
20 May 2006
London
I have upgraded to the latest version 6.10.43. rebooted
noticed that tasks were briefly showing suspended. Check message tab: CPU exceeded 25% suspending tasks:confused:
I noticed a new setting: suspend BOINC if non BOINC cpu usage exceeds 25%. Have now set this to 0 = unrestricted.
Not helped by 2 BSOD due to hal.dll error need to reinstall windows to fix it:mad::(
Looking to get one of thesehttp://www.overclockers.co.uk/showproduct.php?prodid=HD-343-WD&groupid=701&catid=14&subcat=940
If I can wait or it will be
http://www.overclockers.co.uk/showproduct.php?prodid=HD-336-WD&groupid=701&catid=14&subcat=1279
Good call to warn everyone about the new suspend switch which is enforced at 6.10.30+
I'm also on 6.10.43 in a vain attempt to find a version that will have proper job scheduling between multiple projects. But this still isn't fixed as I have recently bounced back and forth between having about 10 wus in the queue up to about 2000 wu's before I had to step in and stop it manually as it showed no signs of stopping its downloads.
By the way Mr Pilgrim57 PARP coming through
Code:
47 Pilgrim57 1,599,918.26 -4,539 -11,419 -22,126 -44,495 +2.01dy
48 kolala 1,592,835.92 -7,420 -18,514 -46,797 -86,748 -
Hi kolala - thanks for the parp. I see you have quite a head of steam for cobblestone production.
I've found Rosetta@home affects both SETI & Climate change work fetch. Have to turn it off to get more Climate wu's. SETI stops d/l of Rosetta until it is down to last wu?
Read about switch for preference file, which I don't have:confused: Can't be bothered at present to create & edit it.
