- 10 Mar 2006
Hi, i hope someone can help me, i'm have an issue with my latest machine set up with BOINC/SETI. THe problem is that every so often its seems to loose its localhost and stop crunching
. So nothing is running when i check taskmanager, and when i look at BOINC manager, instead of it having (localhost) at the top it just has ()? Anyone had problems like this before.
One thought occured to me that it might be cause its installed as a single user, rather than a service. problem is that i couldn't get it to install as a service as it kept wanting a PC username&password and as this computer is a home one, it doesn't have one. any idea how i can get it to install as a service?
thanks in advance
. So nothing is running when i check taskmanager, and when i look at BOINC manager, instead of it having (localhost) at the top it just has ()? Anyone had problems like this before.One thought occured to me that it might be cause its installed as a single user, rather than a service. problem is that i couldn't get it to install as a service as it kept wanting a PC username&password and as this computer is a home one, it doesn't have one. any idea how i can get it to install as a service?
thanks in advance
