Well I thought I knew what I was doing. [famous last words]
Installed manually the not VLARkill prog without realising I needed to edit the app info file.
Ran the rescheduler & it convert 151 files to the CPU seemed good.
I don't know if it played a part but the GPU tasks were suspended - when I resumed them they all became computer error
300+
edited app info to reflect VLAR not kill but BOINC said could find file
& tried to download it
Ran optimised client & saw option to install not VLAR kill. Still no joy
Some GPU units downloaded but not flagged as such & so didn't run
So deleted app info file & reinstalled the optimised client with default setting.
No GPU work & now saying my limit is 2 a day!
By the way using Win7 64bit which is not supported by rescheduler.
[Only backed up project folder not BOINC folder with client state xml
Q. Any one using rescheduler on Win7 64bit?
Do you know what I did wrong?
Should I just not worry about VLAR kill.
