- 22 May 2004
- N.Ireland
Hi guys I am stuck at the moment removing Bolts from my bandit.
There are 8 bolts on the downpipes which connect the don pipes to the engine. I have managed to remove 3 of them but the other 5 are stuck.
The bike is 2nd and I think the bolts have been reused since they are in a bad state. They are 6mm hex/allen keys.
The ones I am trying to get out as soon as you turn the head it just spins since they are rusted so much.
I have tried a driver. Heating them and all. Anyone got any ideas. I would take them out with a spanner but the head is round.
Gareth
Gareth
