Version 7, are you sure! I remember using that back in the stone ages, Sage Line 50 is up to version 14 now. You really should upgrade (just don't use version 13!)
Wouldn't like to comment on how the BOM works for version 7, it would'nt supprise me if the feature was broken knowing how sage release software.
Does anyone know who to use the BOM in sage line 50? I've made a product and it contains many parts using the BOM feature, however when I sell the product the indervidual amounts for the subcomponents are not being reduced, any ideas?
You have to do a stock transfer,
Go into the products module and click transfer, select the BOM item you want to transfer into stock and select a qty, if you have enough components the BOM item will now appear in stock (the qty you put in) and the component qty's will be reduced.
