Bonding acrylic
21 Oct 2014
Hi I'm intending to build a shelf with coolant running through it, after cutting the channels on the cnc machine an making covers/cap for the channels, could anyone recommend an acrylic glue or cement that's really good an waterproof etc, all your help will be appreciated!!! :):)
Hey there.
I have no idea personally but what I would do is this, get you tube up and running and try different search sin you tube, watch what they use and they most fo the time will list what they have used. also when your looking I would try "fish tank" or "marine tank setup"because they use acrylic glue ect especially in marine fishkeeping, they make sump tanks, I think they are called.
Sorry I cannot be more helpful but hope I have sor tof helped.
