Hey, not often I post about a problem so be nice!
But anyways, I had my PC all powered down this morning for a clean as it was v.v.v.v.dusty! After putting it all back together and hooking it back up I noticed the little green led on the DFI mobo was v.dim.
When I turned the PSU on and pressed the power at the front the fans spun for about half a second then went off. I had to keep flicking the power on the PSU on and off until finally the led came on properly and it powered up. Now this has also happened once before when it was all disconnected.
Any ideas?
My PSU is the NeoPower 480w. Mobo is DFI Lanparty SLI-D. Now I do have a problem where sometimes it won't POST but I think that's due to the Maxtor hard drive and the NF4 chipset because AFAIK there is a problem detecting the drive, but a quick reset makes it boot properly. 90% of the time it boots fine.
But back to the other problem, Is my PSU being stupid? It is overclocked and I'm running like seven fans, 2x optical drives, 2x hdd's, a 7800GTX overclocked as well.... is 480w enough??
Thanks!!!!
Any ideas?
Thanks!!!!
