- 5 Feb 2009
I've been trying to see how far I can push my 980 Ti at 3440x1440, but I've been a frustrated with the experience compared to how I used to overclock graphics cards in the past.
At stock (Asus Strix 980 Ti) I get core boosts of 1228-1240MHz.
Overclocking (with max, +110% power limit) seems to widen the range of boost speeds I'm seeing - and even more so with added core voltage.
So, at +240 Core speed, I see boosts from 1467 to 1505MHz in Superposition. Adding voltage I see lower low boosts and higher high boosts.
Adding memory speed seems to lower the boosts a little (possibly running into the power limit).
So I get it's variable, BUT:
Increasing the settings in Rise of the Tomb Raider gave me lower boosts in the benchmark!?! (1452-1490 at default graphics settings; 1414-1478 with higher textures, AA and HBAO, with more time spent at lower clocks).
This is not only confusing and frustrating, it makes it harder to test for stability. I had a driver crash in RoTR but it happened when the core clocks were boosting quite low (around 1414MHz) when they'd been sat over 50MHz higher for a while beforehand.
How do people manage this? And what's the best way a) to wring out the most consistent performance and b) to test to stability reliably?
