My BT fibre broadband is doing my nut in! Its lovely and quick from wired devices but wireless is pretty much unusable these days.
We have probably 8 or 9 wireless phones, laptops, tablets (not in use simultaneously!) and wireless is appalling on all of them, doesn't matter where they are located or what channel the router is set to.
Been in touch with BT but they were unhelpful, they just said the airwaves are congested these days and we've probably got too many other neighbours routers within range so theres nothing they can do.
They suggested a booster/repeater is the only solution and most should work ok with the Homehub 2, has anyone else used one or alternatively know of a decent 2.5/5 dual band router I could replace the homehub with?
Ta
Ta
