- 23 May 2004
- Southampton/Beverley
Hi all,
A neighbour has a Belkin F5D7632-4 wireless modem/router on the top floor of their 3 storey, victorian house. They want to be able to connect a pc in the kitchen to it, but the wireless signal *just* doesn't reach (I've done a site survey using Net Stumbler and it literally dies 1m away from where the pc is - unfortunately moving the pc isn't an option).
I looked at getting another access point, but the Belkin doesn't support WDS. They've no phone line in between the two pc's, so I can't set the router up anywhere else. I did try installing the router downstairs, and wireless connecting the upstairs pc, but all I got on the downstairs pc was "limited or no connectivity", and couldn't access the router. But presumably the wireless signal would be just as weak anyway going down > up as it is going up > down?
So, what is the best solution to the problem? Buy a better, stronger wireless modem and router? Any recommendations? Or are there any other workarounds? Currently wifi card is a d-link dwl-g520.
Many thanks,
Rob.
Many thanks,
Rob.
