Damn I haven't used boot camp in a few years now. Quick google.
https://support.apple.com/en-gb/HT209351
Thanks for that gave it a look no luck as i think its not getting to the create a partion part
Update  still no luck but did run a diskutil list in terminal but not sure what i am looking at to find a fault
diskutil list
/dev/disk0 (internal, physical):
   #:                       TYPE NAME                    SIZE       IDENTIFIER
   0:      GUID_partition_scheme                        *28.0 GB    disk0
   1:                        EFI EFI                     314.6 MB   disk0s1
   2:                 Apple_APFS Container disk2         27.6 GB    disk0s2
/dev/disk1 (internal, physical):
   0:      GUID_partition_scheme                        *1.0 TB     disk1
   1:                        EFI EFI                     209.7 MB   disk1s1
   2:                 Apple_APFS Container disk2         1000.0 GB  disk1s2
/dev/disk2 (synthesized):
   0:      APFS Container Scheme -                      +1.0 TB     disk2
                                 Physical Stores disk0s2, disk1s2
   1:                APFS Volume Macintosh HD - Data     226.6 GB   disk2s1
   2:                APFS Volume Preboot                 81.4 MB    disk2s2
   3:                APFS Volume Recovery                528.1 MB   disk2s3
   4:                APFS Volume VM                      2.1 GB     disk2s4
   5:                APFS Volume Macintosh HD            11.1 GB    disk2s5
/dev/disk3 (disk image):
   0:     Apple_partition_scheme                        +16.5 MB    disk3
   1:        Apple_partition_map                         32.3 KB    disk3s1
   2:                  Apple_HFS Flash Player            16.5 MB    disk3s2
/dev/disk4 (disk image):
   0:                            CCCOMA_X64FRE_EN-US... +5.4 GB     disk4
