Hi
i'm new to MACs & OS X, and want to install win 8 for gaming.
I hve used BC Assistant to create a windows partition, and have loaded my win 7 install onto a USB (had to use MS Windows USB Creator as BC Assistant kept failing).
When i reboot (and hold down the alt key) windows can be selected and setup begins fine.
When i choose the install destination drive it says cannot be installed here as drive is in GPT format (even after formatting i get this error).
So i'm stumped. Its x64 win 8 (can try x32) but otherwise i'm out of ideas...
