"Boot from CD/DVD..." Fail.
6 Apr 2004
Bath, UK
Right, my system specs are
E6300
Gigabyte DS3
3Gb Geil PC6400 CAS4 RAM
7900GS
3 Hard Drives (SATA)
SATA DVD Drive
I had to format my pc and reinstall Winblows, which i have done hundreds of times.
Half way through my instalation it crashed, the media died im sure. Which caused some problems but i got around that by putting in another HDD with Windows on it, and re-formating my Windows partition.
Back to the start.
Set to boot from CD.. get the message "Boot from CD/DVD..." then it just goes on to say NTDLR is missing - ofcourse it is, Windows isn't installed.
So far i have tried...
Different DVD/CD Drives (IDE and SATA)
Different media
Taking out the battery and leaving for a while
Changing the SATA ports around on the ROMs
And other things no doubt.
All thats left which i can think of is
1) Set fire too it
or
2) Hit it a few times with a hammer (Hard)
Anyone got ANY ideas at all? Its literally driving me nuts not knowing why it won't boot from CD.
Thanks
Think i got a result of some kind.. unplugged all the fans in the case - see if it was some kind of power problem, and it booted :)
That's weird, but surely then the fans work when Windows is installed?
I know to reinstall windows I have to unplug other hard drives and flash drives that aren't required.
